- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
so i have been having this problem for about 2 weeks now, and after a lot of tries i still can't figure out where is the problem,
i had 2 versions of max 2015 and 2017 both had vray installed on them not sure which vray was installed on 2015 but i had vray 3.4 installed on 2017,
both worked fine, about 2 weeks ago i opened max 2017 and it loaded up, the UI loaded up and everything, then it froze if i click anywhere on the UI, it tells me (not responding) and tells to close the application. after some tests of opening and closing max i figured out it's not just a mere isolated issue,
both 2017 and 2015 did the same thing, and i tried clearing the user preferences file located in the appdata/local/autodesk/3ds max folder to no avail
when i uninstalled vray though from 2017, max worked fine, if i reinstall it the problem happens again.
i then installed max 2016 and installed vray 3.3 on it, and i reinstalled max 2017 with vray 3.4 again and they both worked fine for about 2 weeks, yesterday the problem happened again, now all of them do the same thing, max 2017 and 2016 and 2015. each with a different version of vray
for the love of god i can't figure out the problem....
i also tried updating my VGA driver nothing changed,
specs:
core I5 3.1GHz
16GB ram
nvidia geforce 650 ti
windows 7
