3ds max render doesn't support texture baking, rendering disabled
Hey, when I'm trying to render Material ID to Colour map (to use in Quixel Suite), I have this weird issue, and after this I simply can't press render. Why something like this happened?
Btw. Please ignore that everything is green - before messing up with colours (which will take a while) I just want to see if I can render anything. And, we we can see, I can't.
3ccufKK
Hopefully someone will be able to help.
fla3d
Arnold and ART doesn't support render to texture, you have to change to Scanline.
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I believe that @fla3d is correct, your current renderer isn't supported by RTT.  If you are just making Object ID's a self illuminated standard mat should do just fine.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Hi there,
I  did a same issue and it works perfectly. Thank you so much for your help!
