Im going to try and make this as short winded as possible as this problem is getting quite frustrating.
When I open a new 3ds max scene I have no issues, things seem normal. I close max, reopen and all of a sudden im getting these "Missing Script/Plugin" dialogs when I right click on the viewport. The render is installed fine, the dialogs for the renderer are even present at the bottom of the right clicked menu. If I try to use a script like the import from Megascans feature, I have to re install the max script because its not holding onto it after restart. What gets even funkier is if i close this 3ds Max instance and open a new one, the dialog boxes that show "Missing:" doubles up. It gets to the point where I can no longer see on the screen the Vray options that I need to use.
The only way I have found to fix this is to delete the ENU folder and let it reinitialize. The problem there is it takes time to redo hotkeys, menu setup etc and is not conducive to a clean workflow. PLEASE HELP!
