3ds max displaying 0 points after loading Scan File
petrenkoivanka025
Message 1 of 13
petrenkoivanka025
Hi!
I'm completely new in 3ds Max and now currently trying to work with LiDAR to create surfaces, objects, animation etc. But I've face with a problem at the very first step: when loading scan file it displays nothing no metter what file size (from 270Mb to 3Gb) or extention (.rcp, .rcs, .las, .ply) I load.
I also tried to fix this situation following this article https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Point-cloud-is-not..., but it didn't help.
Could it be possible because I installed trial version and it has reduced functionallity?
Thanks in advance!
Replies (12)
Message 2 of 13
RobH2
Are you able to upload a file some of us can test? Also, what version of Max? Have you installed any 3rd party scripts or plugins that relate to LIDAR files, scans and their processing? Lastly, what graphic card do you have and what driver version?
As far as I know, there isn't a crippled or function-reduced version of Max. If you have a licenced version of Max, you have everything it comes with.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 3 of 13
Diffus3d
Does it show up in a render?  If so, maybe it's related to adaptive degradation?
Best Regards,
Message 4 of 13
petrenkoivanka025
Hello!
Yes, I can download some files to test. I don't use any 3rd party scripts or plugins, only ReCap trial from Autodesk.com for LiDAR pre-processing.
3ds Max 2025
Processor          Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz   2.00 GHz
Installed RAM   32.0 GB (31.8 GB usable)
System type      64-bit operating system, x64-based processor
Edition Windows 10 Pro
Version 22H2
Display adapters: Intel(R) UHD Graphics 620
Disk drives: TS512GMTE220S, WDC WD10SPZX-08Z10
Message 5 of 13
Diffus3d
Yes, as in it does show up in render?  Any luck with the adaptive degradation?
Your GPU is pretty underpowered.  That's almost certainly the problem.  It's not really a production 3D card, so probably it can't handle the sheer size of a point cloud.  Not much anyone can do to fix that I'm afraid.
Best Regards,
Message 6 of 13
petrenkoivanka025
Hello! There's nothing appears after render, just black screen in both cases when adaptive degradation on or off.
Message 7 of 13
Diffus3d
Hmm.  You'd think even with an unsupported card it would render, but who can say?  Posting files might help so we can see if others can reproduce the problem.
Best Regards,
Message 8 of 13
petrenkoivanka025
Oh, I see, it's time to buy new PC.
Thanks for answers.
I just thought if it works in Infraworks, so it will work for 3ds Max. There I could even recognize some objects in point cloud, but it's not the level of detalization I needed.
Message 9 of 13
petrenkoivanka025
Unfortunately, files are under NDA, I'm not allowed to share them.
Message 10 of 13
Diffus3d
In many cases you can add GPUs to a computer, your intel one is part of your motherboard most likely.  (I could be wrong.)  If you want I can try to test your file before you spend any money like that, make sure things are working.  Otherwise, maybe you can test it on another machine.  I'd hate for you to spend money based on the comment of some forum comment without being sure.
Best Regards,
Message 11 of 13
petrenkoivanka025
Thanks so much for help! I'll try another PC before any purchase.
Best Regards.
Message 12 of 13
Diffus3d
Understood.  Wishing you the best.
Best Regards,
Message 13 of 13
RobH2
Alfred is right, it would be good to at least try it on a powerful and proper machine before spending the money. However, if you'd like a new computer anyway, one with better hardware for Max, then this might be the excuse you need to buy it. And best of all, even if it doesn't solve this issue, you'll still have a much better machine for Max for all other work going forward.
How about letting me or one of us sign an NDA as well? I'm a Product Designer, I've signed and maintain 100s of NDAs and I can give you references as to the security I provide for them. I could look at the file and then promise you I'd destroy it and wipe it from the drive.
Rob Holmes
