3ds max Backburner render element renders are overwritten
- Mute
- Permalink
- Report
hello!
There is a problem with saving render files when rendering via BackBurner. I'm doing some rendering jobs through batch render.
if I make a render and do not specify a specific name and save path for render elements, I get the render + render element file for each task named correctly.
If I specify where to save the render element and how to name it, then it does not receive the proper prefix of the task name and is simply overwritten for each task every time.
without a path for the element 10 tasks + 2 elements, I will get 30 files. 10 renderers + 20 elements
with the paths, I will get 10 renders +2 element files that will be overwritten on each task
I want to get the correct names for the elements and specify where to save them, it is not always convenient when everything flies in one pile next to the main render.
