3ds max 2024 SME does not show all parameters
infoY9SRW
infoY9SRW
I have a problem in the new Material Slate editor.
Unfortunately, when selecting a map, the parameter window does not transform correctly. As you can see in the picture, the right side of the color correction map is cut off. This is also the case with other maps like Bitmap.
I have not had this problem with 3ds Max 2023. Is there perhaps already a solution for this or is this a bug that still needs to be fixed?
Hope you can help me further.
Thank you and best regards
giuseppe.schiralli
Thank you for the report.
Can you please check https://forums.autodesk.com/t5/3ds-max-forum/problem-window-setting-are-cut-inside-slate-material-ed... for a possible solution?
-Giuseppe
Giuseppe Schiralli
3ds Max - QA Analyst>
infoY9SRW
Hi Giuseppe,
thank you for your response.
I have tried the method that can be found in the link. Unfortunately the problem persists.
infoY9SRW
Morning Autodesk Community,
maybe someone has another idea how to solve the problem? Unfortunately the settings in "High DPI settings" did not help me in this case.
I created a comparison video, between 3ds Max 2023 and 2024, on the same computer.
ogan
Community Visitor
Community Visitor
I have the same problem on 3Ds MAX 2024.2.1
