3ds Max 2023 Menus Opening in Wrong Position Issue
sakaenes
sakaenes
I'm using 3ds Max 2023, and when I click on a menu button (e.g., Wireframe), the menus open in far-off positions on the screen. This issue makes it difficult to use the menus, especially on a large monitor. I've checked the screen resolution and scaling settings, but the problem persists. How can I ensure the menus open in the correct position?
Does anyone have any solutions or has experienced a similar issue? Thanks in advance for your help!
  • menu
RobH2
It generally happens when you have large 4K monitors. You say you've checked the screen resolution and scaling settings, but what actual settings are you using? Can you screenshot them from both your video card properties page and the Windows monitor settings page? You might still have something set incorrectly.
See if this link helps:  https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-2020-4k-monitor-dpi-problems-still/td-p/1011558...
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
ads_decatae
Hello @sakaenes,
There is a known issue when using two monitors with different scaling settings, and a dialog or tool opened on the second monitor. Could that be your case? Often, that issue can be resolved by simply closing the dialog on the second monitor. If the problem persists, you might consider setting the same scaling for both monitors and modify their resolution as necessary.
Let us know if that helps.
sakaenes
Merhaba, bu açıklamayla ilgili sorunu araştırdım ve dediğiniz şekilde ölçeklendirmeleri ve çözünürlükleri inceledim. Sorun Çözüldü teşekkür ederim.
sakaenes
Sorunum çözüldü çok teşekkür ederim.
