Something went wrong after Windows 10 got itself updated lately. (Maybe not, but I noticed the problem after the update)
I used to press "V" to bring up the viewports menu to switch between viewports, but it won't work now. The same with the quad menu.
The menu looks normal, but I can't click on any of the buttons, 3ds max would freeze in this status, and I have to switch to another program to get it back to work.
I have found this post,
https://forums.autodesk.com/t5/3ds-max-programming/3ds-max-2018-menu-problem-cant-click-on-sub-menus...
and thought that it may be a similar issue because I could select viewports in the test menu properly, but the "MenuShowDelay" script didn't fix my problem.
Solved by brentscannell. Go to Solution.
Hi @kou.t
Can you confirm the exact windows version that you are using at the moment?
Are you by chance using a non english IME? You may need to may need to enable a special compatibility mode setting in windows:
Similar post to Brent above, I deleted it
i have same problem but in my case i cant select previous ime 😞
this problem is second time in my work same problem in max2019 so, i change version to 2020
i need some help plese.
