I want to change 3ds max from design model to classic model
Solved by brentscannell. Go to Solution.
also read the blog article that is referenced in the above link
DarrenP
To get that option screen back, you can use these steps:
Step 1. Run 3ds Max with the one of the following command line options: -df, -dfc or -dfd
You can do that by editing your shortcut or by running 3dsmax.exe from a command line.
The three options are:
-df: gives you the dialog again so you can chose which mode you want to use
-dfc: no dialog, runs 3ds Max in Classic mode
-dfd: no dialog, runs 3ds Max in Design mode
Your shortcut path should look something like :
"C:\Program Files\Autodesk\3ds Max 2020\3dsmax.exe" -df
Step 2. Remove the user settings
And rename or remove your user settings C:\Users\YOURNAMEHERE\AppData\Local\\Autodesk\3dsMax\2020 - 64bit\
The folder you need to rename is: ENU for en-US localization.
The next time you start 3ds Max you'll can choose your initial 3ds Max experience again if you've used -df. Or you're straight in Classic mode (with -dfc) or Design mode (with -dfd)
