3ds Max 2017 not importing CATproducts
Max (3ds Max 2017 SP3) is refusing to import CATproducts.
File > Import > Select CATproduct > Open
Then the import settings dialog (that I usually see when I import cgr's) pops up.
Then... nothing.  It just blinks out immediately and my scene is empty.
It's been a while since I have imported CATproducts but I don't recall seeing the cgr import settings dialog.  Usually it's a bigger dialog box where you can see the progress.
But that dialog doesn't appear.  Just... nothing.
What am I doing wrong?
Diffus3d
Hello @Anonymous ,
Possibly they were created with a newer version of whatever makes CATProducts files released after 2017.  If they made any changes to how the format works under the hood, it might cause a problem like you describe.
Have you tried other settings in the Hierarchy Mode?   What if you convert to mesh?  Anything?
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
