3ds Max 2017 4k resolution problem
I have a problem with the 4k resolution of 3ds Max 2017. I searched around the forum, and found no problems similar to mine.
1. If I start 3ds Max 2017 with the native resolution set-up by the app, then some of the texts of the UI system become ineligible.
2. However, if I change the resolution settings through High DPI override, setting it to the "System" or "System (Enhanced"; then, despite that the texts are readable, the resolution of everything in the app is noticeably lower on my 4k screen.
I have my scale and layout set correctly through the Windows 10 settings, as instructed in this forum: https://forums.autodesk.com/t5/3ds-max-forum/compatibility-with-4k-monitor/m-p/6684901
But this did not solve the problem for me. It would be great to have high resolution while being able to read the texts.Windows resolution settingsWindows resolution settings3ds Max system resolution3ds Max system resolution3ds Max app resolution3ds Max app resolution
Replies (0)
