3ds max 2016 crashes, CONSTANTLY
Augh, I have no idea what I'm doing wrong here. I have 3ds max 2016 on Windows 10 and it crashes all the time when I do random stuff; when I save, apply random modifiers, move something. Honestly I need a solution, otherwise I don't think I can keep using this program. I've looked up a couple possible solutions but nothing seems to work. Did I do something wrong? Is this just a buggy program? I mean, pardon my French but it's really starting to f**king p*ss me off. Literally all I'm trying to do is rename some bones (I NEED to rename these bones, there's no way around this) and I cannot even finish this because it's always crashing. Please, somebody help me out.
xathian
Observer
Observer
II'm having the same problem, it just keeps randomly closing (no actual error report). In fact, I even tested and have seen it happen without doing ANYTHING. I opened Max and opened my program. And then just sat back and left the computer alone and after about 10 minutes it just closed. I see a lot fo this being blamed on AMD, I am not using an AMD card, I have a 980Ti
If it crashes constantly no matter what you do then it will be difficult to suggest a solution.
I'm mostly still on max 2015, but I do have max 2016 too and I can't say I find it particularly unstable...
If it crashes all the time in a particular scene containing some particular object / thing- like your scene where you're renaming bones, then thats another thing, probably a more isolated bug.
If its general instability, there are a ton of things to try, but that was kind of my point, its hard to suggest anything constructive..
In general, you have your common list of stuff to check:
*Do you have the latest service packs for max instaled? 2016 was one of those rare versions thet actually got 3 SPs.
*Do you have previous max versions working ok for comparison?
*Is your computer hardware otherwise completely stable? (Mem test etc)
*Do you have the latest drivers for your Gfx card?
*What IS your hardware config? How much RAM? GPU? etc..
*Are you on a network? If so, is max affected by any network paths etc..
Also.. you could always download a 2017 trial and see if you have the same problems...
Stuff like that... Good luck
genius.tv
If you're using a Wacom tablet that can also cause instability in 3dsmax and Windows in gerneral. After I removed the tablet and returned to using a mouse, I've noticed considerably better stability.
