3DS Max 2012 - send to Mudbox not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there!
I´ve searched for quite a while but I wasn´t able to find a solution for my problem, so if there already is a topic for this problem I apologise, I haven´t found an answer that would solve my problem.
I own the Autodesk 3ds Max Entertainment Creation Suite Standard 2012 and I´ve installed all of its components for some time. No I wanted to try out the workflow between Max and Mudbox but I have a Problem here:
The "Send to Mudbox" Option doesn´t work. If it is not running, Mudbox opens, but the scene is empty. Even if I have Mudbox open with a empty scene nothing is sent.
The Status Line in Max shows "Connecting to Mudbox" but nothing happens (new scene, add to scene, update scene - nothing works).
The other way around it is the same, after I click Update in the lower right corner it shows "connected to 3Ds Max" but the model doesn´t arrive in Max.
I´ve installed both Max and Mudbox on C, the latest Updates for both Tools, I own a valid License for both of them and I´ve tried to run Max and Mudbox as Admin, but nothing helps.
If someone could help me with this problem I would be very gratefull, as for now I am able to bring the models across once I´ve exported them but the connection feature looks very nice and convinient.
Thank you very much in advance!
