3DS Max 2012 Curve Editor Problem
This widget could not be displayed.
I am animating a polygon mesh with bones using a CAT rig. Whenever I go to the Curve editor in order to change the Frames or Values in the Key Entry: Tack View, the tangent button icons start to flicker and I'm unable to type in a value with the keyboard for about 15-30 sec until the flickering stops.
Never the less the mouse functions are still given and I can manipulate the tangents manually, but it's especially frustrating when I want to set the Global or Local Weights of the CAT rig to 100% or if I want to work proper.
I have the SP1 and HF2 for 3DS 2012 installed.
System Spec:
Windows 7 Ultimate; 64 bit; SP1
Intel Core i7 950 @3.07GHz
12 GB RAM
NVIDIA GeForce GTX 470
So, I'd like to know if it's an issue with the program/version or the hardware.
I too am experiencing this exact same problem, was this ever solved?
