3D Studio MAX 2026 issues
hdizajn
hdizajn
First, why is it so hard to find an actual 3D Studio MAX forum?? Is the software being discontinued?!
Next, not sure if I should report these issues somewhere, haven't used Autodesk customer service for a while but there are two issues so far. Each time I open an older scene I have to go to viewport settings because it's completely black and switch to "2 default lights". For some reason "1 default light" is completely black. I even tried saving a new default to be 2 lights, overwritten the old "standard" but it's still black.
Second issue is with the tile map. I literally can't click it's main nor grout texture in standard material editor. I can only add them in slate of course, by connecting.
JasonLuckett
Agreed the forum is junk and a pain to access, I can get into Vray forum in two clicks.
There are no technical customer support here from 3dsmax employees, just the good will of super users.
I had a problem with Chaos Vantage and within a week they updated the software and rolled it out.
anuj_abhiwan
3ds Max 2026 Issues (Short Summary):
Performance Lag: Some users report slow viewport navigation and rendering delays.
Plugin Compatibility: Older plugins may not work properly with the 2026 version.
UI Glitches: Occasional UI freezing or unresponsive menus.
Export Errors: Issues while exporting to certain formats like FBX or OBJ.
Crashes: Random crashes during complex scene handling or rendering tasks.
hdizajn
Yeah, sluggish viewports is what I'm experiencing also.
whitebirchstudios
3DS MAX 2026 is a hot mess!
scummingGKLP4
Observer
Observer
Installed the 2026.2 update today.  Makes no difference, anything with high poly count needing editing and it crashes.  Can't even convert to poly = crash.  Boolean...forget it
