3D models in 3ds max
a_hlavatova
a_hlavatova
Hi, I am learning 3ds max, but I cannot find some 3D models like bed or lamps how it is in sketchup where is 3D warehouse and I can download what I want. Does 3ds max have something like this or I have to download it another way? Thanky you
Diffus3d
You can use the File->Import menu to bring in models from external sources, but 3dsmax doesn't have a library picker like 3D warehouse.  Some renderers do like Chaos Cosmos, but in 3dsmax since there are so many renderers available the asset packs are broken down by renderer instead of by software.  Usually, but not always.
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
a_hlavatova
Thank you very much, do you know some websites where I can download for free?
Diffus3d
I think Substance Share has some free 3d models, as does turbosquid.com and cgtrader.com.   There's a ton of sites, just google free 3D model and you should find some no problem.
Best Regards,
VincentSheehan
Sketchfab is also another good resource.
https://sketchfab.com
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
raiden_xavier
Autodesk Support
Autodesk Support
Hi @a_hlavatova,
I hope you will enjoy your stay in the forums and do great things with the software.
Lots of great information from the other users here.
It would be great if you could give feedback and mark any that helped as the solution.
We look forward to hearing from you.
Many thanks.
