3ds Max Design Visualization Workflows
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max design visualization topics.
STP/STEP import now has problems in 2024
3 REPLIES 3
Ross2006
981 Views, 3 Replies
Our team has just upgraded from 3ds Max 2018 to 3ds Max 2024, and we've noticed some new problems when importing STEP files. The ATF Converter (STEP translator) occasionally had some trouble with certain torus shapes back in 3ds Max 2018, but now it's much worse and has started to affect our productivity since we need to manually fix these glitches with each new import.
I created some torus and partial-torus shapes in my CAD program and exported the file as STP. You can download the file in the attachments and test it yourself.
Here's how the import looks in 2018 - absolutely perfect:
Here's in 2024 - quite broken:
As you can imagine, toruses appear frequently in our CAD models so this is a bit of a dealbreaker.  Hopefully this helps get to the root of the problem and we won't have to stick with 2018
Labels (5)
3 REPLIES 3
RobH2
in reply to: Ross2006
I was unable to reproduce the issue. I uploaded a video showing opening in  my CAD software to see if it looked normal there first. Then I opened in Max and it looked good as well. STL Check found no errors.
Have you tried exporting from CAD as  something other than STP and imported that? I mean, if you just need to get it into Max, it doesn't stay a STP once in Max, it's just a mesh and you can export another or the same format once you are done with it.
Have you tried and ENU reset?
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
wernienst
Unfortunately, you are right - partly.
Left: Convert to Mesh Off, right: Convert to Mesh: On
wernienst
in reply to: wernienst
The problem is not the STEP importer. It's the mesh creation process inside Max' Body Objects.
Left: Display Options Both, right: Curves
