Imported step file from solidedge - issue in 3dsmax
nitheeswarreddy
nitheeswarreddy
I created a step file from solidedge surfacing,so it is a surface. when i imported in 3ds max the surface is showing as large spheres .why is this happening?        I imported formats like step,fbx,obj. the output is similar in all cases.                                           When i import a single part of surface,it is normal,but when i imported the whole assembly the problem occurs.
MartinBeh
To me, it sounds like the issue is how you process the surface in solidegde.... but IMHO you need to provide some sample files for us to test.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
nitheeswarreddy
MartinBeh
