Announcements
3ds Max crashes while rendering still images and animations with Corona Render
nsbuller
nsbuller
As the title suggests, every time I render still images or animations in my current scene using Corona Render, the program crashes. My computer is capable, I have an RTX 4070 Ti graphics card, Intel i9 processor, 64 gb of RAM and 12 gb of VRAM. I've attached the dmpuserinfo file here, I hope that is helpful. I am relatively new to this software and I'm curious to find out what is going on and fix the problem. Please let me know if there is any other helpful information I can provide. Thank you
Edit: I downloaded older versions of the software (3ds Max 2023 and Corona 9) and was able to render both a still image and animation within the same scene without it crashing. I'll continue using the older software for now and perhaps resume with the current software when it's more stable.
ahmedbilal9870
Community Visitor
Community Visitor
It's great to hear that you were able to find a workaround by using older versions of the software. Software crashes can be frustrating, but sometimes switching to a more stable version is the best short-term solution.
To address the crashing issue with your current software (3ds Max and Corona Render), here are some steps you can take:
  1. Update Your Software: Make sure that both 3ds Max and Corona Render are up-to-date with the latest versions and updates. Sometimes, crashes are resolved in newer releases.
  2. Graphics Drivers: Ensure that your graphics card drivers are also up-to-date. Outdated drivers can sometimes cause compatibility issues.
  3. Plugin Compatibility: Check if you have any third-party plugins or scripts installed in 3ds Max. Incompatibilities or outdated plugins can lead to crashes. Try disabling them one by one to identify the problematic one.
  4. Scene Complexity: High-poly scenes or complex materials can sometimes overload the system. Try simplifying your scene or optimizing your materials if you suspect this might be the issue.
  5. Render Settings: Review your render settings in both 3ds Max and Corona Render. Some combinations of settings may lead to instability. Experiment with different render settings to see if the problem persists.
  6. Corona Render Settings: Specifically, check the settings in Corona Render, as it seems the issue is related to rendering. Make sure all render settings are configured correctly for your scene.
  7. Hardware Stability: While your hardware is powerful, it's also essential to ensure that your system is stable. Check for any overheating issues, and run diagnostics to confirm that your RAM and GPU are functioning correctly.
  8. Error Messages: Pay attention to any error messages or log files that are generated when the software crashes. These can provide valuable clues about the cause of the problem.
  9. Corona Render Support: Reach out to Corona Render's official support channels. They may have encountered similar issues and can provide guidance or updates related to your specific software version.
  10. Backup Your Work: Always create backups of your work before attempting to troubleshoot or make significant changes to your scene or software settings.
If the issue persists and you decide to continue using the older software versions for stability, that's a reasonable decision. However, it's a good practice to periodically check for updates and revisit the latest versions to see if the problem has been resolved in future releases.
evgenthik2
Community Visitor
Community Visitor
Добрый день, решили как то свою ошибку, в чем была проблема?
