imgtag UI Gets wrong Gamma when using OCIO
sandbergGJZSN
sandbergGJZSN
When using the old gamma workflow, all UI icons look correct.
When i switch over to OCIO all UI icons still look good, except icons that use imgtag UI.
Is there any way of just keeping the UI elements to look the same as it did when switching modes?
It would be nice if either imgtag has an Ignore OCIO or something as a setting... at least it should work the same as all other UI icons/image inputs.
sandbergGJZSN
it appears it was caused by me copying bitmaps.. they lose the colorspace setting when copying them, which maybe should be looked at since afaik cant set them after.
In general i wish that the bitmaps in UIs wasnt affected by this new color management system until i specifically told it to... that any old ui just worked the same as it used to.
cuneyt.ozdas
Is it possible for you to provide a code snippet showing how you load the bitmaps and use ImgTag?
Cuneyt Ozdas
Principle Software Engineer
