To import a DWG file into AutoCAD while preserving all the layers and objects correctly, you can follow these steps:
Launch AutoCAD: Open the AutoCAD software on your computer.
Create a New Drawing: Start a new drawing by selecting "New" from the File menu or by using the "Ctrl + N" shortcut.
Access the Import Options: Go to the File menu and choose "Import" or type "Import" in the command line. Alternatively, you can use the "Ctrl + I" shortcut.
Select the DWG File: In the Import dialog box, navigate to the location where the DWG file is saved. Select the file and click "Open."
Configure Import Settings: The Import dialog box will display various import options. Ensure that the "Import" tab is selected. Here, you can specify how you want the DWG file to be imported.
Check the "Preserve" or "Retain" options: Look for options like "Preserve Objects," "Preserve Layers," or "Retain Original Layers." Make sure these options are selected to retain the layer structure and objects from the original DWG file.
Review other import settings: You may have additional options to choose from, such as unit conversion, scaling, or coordinate system alignment. Adjust these settings as needed.
Click "OK" to import: Once you have configured the import options, click the "OK" button to start the import process.
Verify the imported DWG file: After the import process completes, AutoCAD will display the imported drawing on the screen. Verify that the layers and objects are preserved correctly by checking the layer names and their properties.
and you can follow this site for more info Passive income
