wire parameters
hi, friends, I have two cases of wire parameters issue. 1- the right one when the dummy has movement on the path ( back and forth) should the arrow shape rotate just the one direction and (desired amount) degree.2- the left one should the starting point of the dummy movement be middle of the line(middle vertices) when it goes to right the right Cylinders should it grow (Diameter) and the left one should shrink down (Diameter)and inverse.
thankyou so much
