Announcements
Wire Parameters & Rotation to Local Axis?
peterjung
peterjung
Hi there
I have seen this type of problem discussed in several places however the suggested solutions have not been clear to me and I have not been able to understand.
The scene below shows the issue I have.  The red, green and blue  shapes are all linked to respective dummy objects.
I have set up wire parameters to do the following:
I tried posting a screencast but seems to be an issue:
https://autode.sk/37Wj9g9
Dummy Red X rotation rotates Dummy Green in X axis
Dummy Blue Z rotation rotates Dummy Green in Z axis.
As long as Dummy Red is not rotated the rotation of Dummy Green is ok.
However with Dummy Red and Dummy Green rotated in X axis Dummy Green still rotates in the world Z axis rather than the rotated local Z axis.
Can someone please give a basic simple method on how to resolve this problem?
Thanks in advance!
peterjung
I have found some suggestions that you should use a Helper point as the link parent for the object you want to rotate and rotate the point.
I tried this but I am still getting something wrong.
Dummy-Blue Z rotation is wired to the Point-helper Z rotation
Dummy-Red X rotation is wired to the Point-helper X rotation
Dummy-Green is linked as a child to Point-helper
<iframe width="640" height="590" src="https://screencast.autodesk.com/Embed/Timeline/eb6e4a85-19d2-41df-8be7-afd70db5ac91" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Same result as before… what am I missing?
leeminardi
Please post the Max file.
lee.minardi
leeminardi
I think the following does what you want without any helpers.
lee.minardi
peterjung
Hi Leeminardi
Thank you so much for taking the time to look at this - you solution is logical and simple... seems I was overthinking this !  I just got time just now to look at your solution and I think I would do well to remember the K.I.S.S. principle.
Thanks again and I really appreciate your help!
