Announcements
tyFlow animation does not stop
mikko_kovasiipi
mikko_kovasiipi
Hi. This is a tyFlow question but I was thinking if some of you could help me a bit. I'm trying to learn tyFlow and I have made a little scene where a ball drops in to a small groove. Everything works quite nice, but the ball just doesn't stop.  The ball is PhysX shape as ball and others are PhysX Collisions as mesh's. I haven't touch the frictions or any other parameters yet. So is there some "rest" parameter somewhere or how could I stop the ball?
See the example in the attached file.
Mikko
RobH2
You might think about posting this in a Tyflow forum. It's probably just a wiring or parameter setting that needs some tweaking. It's likely not something related to Max's underlying functionality. You might get a faster response in a Tyflow specific forum is my point.
If you do solve it, do post here so it helps other who might have the same issue. 🙂
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
mikko_kovasiipi
The answer was just in front of me. The Damping option in the Physx Shape properties.
Mk
RobH2
Thanks for that. It may help someone else.  😀
Rob Holmes
