3ds Max Animation and Rigging
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
Slow performance while painting skin weights
3 REPLIES 3
holchangomes
400 Views, 3 Replies
As seen on video when painting skin weights performance is poor, i see a spike on, and only on, my 4th processor thread which i suppose is a single thread operation but should be this slow? My CPU is from 2016, is not that old too see such poor performance, mesh is 30k poly, about ~80 bones rig, tried to change tree depth and lag rate as seen on some tips on a post from someone with the same problem, didn't work.
3 REPLIES 3
RGhost77
in reply to: holchangomes
It is know bug in older versions of max. It was already fixed in modern versions.
Royal Ghost | veda3d.com
holchangomes
in reply to: RGhost77
Even in 2021? I will install the 2023 one then and try, thanks for the tip/help.
holchangomes
Installed max 2023 and its all fixed, thanks for the help.
