Sliding mechanism rigging
giuseppetonello
giuseppetonello
I need to rig three parts: a rail, a slider, a mechanical arm(or crank) and a dummy, like in this picture:
The dummy is free to move in all directions and it should control the arm and the slider, which must move only inside the rail.
In other words, whenever you move the dummy you should be able to push or pull the linked arm and slider.
Joey
Replies (7)
leeminardi
I assume by "all directions" you mean full 3D (x,y,z).  This post may be similar to what you want to do excpet that your "cable" is a straight line in which case there may be a simpler solution.  Please post your Max file and I'll take a look at it.
lee.minardi
leeminardi
Here's a rig that I think will do what you want.
A position script controller is assigned to a dummy (DummyOnRail).  It's position is first guessed to be midway between the two ends of the line named "rail".  The distance from DummyOnRail to DummyManipulator is compared to the length of the arm.  If it's greater then a new guess position is made midway between end 1 and the midpoint.  If not then the new guess is midway between the midpoint and end  2.  The process is repeated 10 time yielding a solution if possible.  If DummyManipular is too far away then DummyOnRail snaps to the end of the rail.
e1 = getknotpoint rail 1 1
e2 = getknotpoint rail 1 2
v12 = normalize(e2 - e1)
armLen = arm.height
g1 = e1
g2 = e2
gm = (e1 + e2)/2.
i = 1
while i < 10 do
if (distance gm dumMan) > armLen then
g2 = gm
gm = (g1 + gm)/2.
else
g1 = gm
gm = (g2 + gm)/2.
i = i + 1
) -- while
gm
lee.minardi
leeminardi
I think this is a better solution than my last post. It uses some simple vector math to find the point on the rail.
armLen = arm.height
pp = (dot (dumMan - e1) v12) * v12 + e1
a = distance pp dumMan
b = (armLen^2 - a^2)^0.5
p = e1 + v12 * ((distance e1 pp) - b)
if armLen > (distance pp dumMan) then
p
else
e1
Point pp is the projection of the dummy manipulator onto the rail. a and b are two side of a right triangle formed by dummyManipulator, pp, and the solution point p.  If the dummyManipulator is too far away the arm snaps to end 1.
lee.minardi
giuseppetonello
Thanks, @leeminardi let me get my head around your solution and get back in a while.
Joey
leeminardi
@giuseppetonello The following illustration may help you understand the script. Green arrows are vectors. P, PP dumMan, e1, and e2 can be considered vectors as well.  I visualize them as vectors going from 0,0,0 to the noted point.  Of course, they are free vectors and may be positioned anywhere.   The dot product of a vector (e.g., (dumMan - e2)) with a unit vector (v12) yields the magnitude of the vector projected onto the line of the unit vector (equals b in this example). Let me know if you have any questions.
lee.minardi
giuseppetonello
@leeminardi I've never seen a while loop in a position script. Can you explain what every iteraction (e.g. while i < 10) does? Also, the position script on the post above seems different than the one on the attached file.
Joey
leeminardi
The position script in SLiding Rod .max (post #3) uses a numerical methods technique to determine the location of the slider.  It uses a series of guesses for the location improving on the guess with each iteration.  This solution was overly complex for the problem and you can ignore it.
The position script in SLiding Rod01 .max (post #4) uses an analytic approach.  It is a beter solution. Let me know if you have any about this solution.
lee.minardi
