Serious error with skin modifer mirror function
I use 3ds max 2018 for skinning my model. After I complete adjust left side of model with weighting vertex I mirror to other side and this serious error occur . The right side of the model is not move at all. Before mirror , the right side was fairly good. It only needs some adjustment.
This is the second time I found this error. It also occur to me by 3ds max 2017.
I reset the 3ds max and merge the file mirror with skin modifier. It resolve the problem and mirror well.
I think Autodesk should repair this problem.
I attached my max file for testing purpose.
Thura Thein Tin.
Had to reset x-from, then mirror skin weights worked with your file.
Something to keep in mind when preparing a mesh for skinning.
The problem is solved. Morpher is still working.
Thanks.
But I'm sure. I do reset X form prior to skinning.
