Hi.
Might I missed something, but seems to me a bit weird. So let's go to try this test.
I create a point helper, rotate it to a random angle along all axis. Then I will create a key, press local rotation, move the time bar to frame 100 and rotate the point along one axis, it doesn't matter which one.
I would suppose that when I will play this record, the point will rotate just along one axis, but not. It has just the start and the end position, but rotation between these points is random, so It is not rotation along one axis which I would like to have.
How can I repair it? I have already tried to switch rotation controller from Euler XYZ to Linear Rotation, which solved the rotation issue, but then I can't see any keys in Track curve editor...
Oh...Any help will be appreciated
