Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Rigging question - constrain object to intersection between 2 lines
markus
markus
Is there a way to rig this so the pink box will always be in the position where the two lines intersect? What kind of controller or IK should I use?
(sorry for double-posting. I also posted this in the main forum)
Replies (7)
markus
Fyi, The to splines are on the same 2D plane, and the vertical one is static, while the other is moving and rotating.
markus
OK, I got a solution from Daniel on the Stack Group on facebook.
Check it out here on Stack on Facebook
He solved it using a script controller, a plane and some points. Kudos to Daniel on Facebook for demonstrating his powerful math and scripting skills!!
domo.spaji
Path constraint box with vert. line as target path,
lookat constraint other line to box as lookat target.
You can transform/animate all 3 objects - lines intersection will be where box is - that is effectively same thing as you ask for
markus
Thanks for the idea @domo.spaji
Edit: I posted a reply to the wrong post!
markus
Daniel has posted an Idea to make this into a regular controller in 3dsmax, which could be useful for mechanical rigging!
3dsmax Ideas
leeminardi
Here's another approach that uses a position script controller that finds the intersection of two 3D lines.  If the lines do not lie on the same plane the intersetion is defined as the mid-point of the shortest distance between the two lines.
p1 = getKnotPoint line1 1 1
p2 = getKnotPoint line1 1 2
p3 = getKnotPoint line2 1 1
p4 = getKnotPoint line2 1 2
pa = p2
pb = p3
for i = 1 to 10 do
dot1 = dot (pa-pb) (normalize(p3 - p4))
dot2 = dot (pb - pa) (normalize(p2 - p1))
pb = pb + dot1 * (normalize(p3 - p4))
pa = pa + dot2 * (normalize(p2 - p1))
pIntr = (pa + pb)/2
lee.minardi
markus
Thanks, @leeminardi ! Thats a very good solution!
