Plane jumps. Why ?
Plane jumps. Why ?
santaclous
Message 1 of 10
Plane jumps. Why ?
santaclous
Hello. I have a problem. Plane jumps. Why ?
When I delet one of marker, plane stop jumps.
File attached. Everyone can try.
Solution. Change Position TCB -- >  Position XYZ
Replies (9)
Message 2 of 10
RobH2
1. Have you looked at the Curve Editor and set all the curves to 'Linear?'
2. Have you created it again but by setting your start key first instead of coming back to set it? That could have caused a problem.
3. The file you uploaded is just a single plane with no animation on it. Maybe upload it again.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 3 of 10
santaclous
Yes. Clear the timeline, add box and make your own animation like mine. It will be the same problem.
Message 4 of 10
MartinBeh
That seems like a very simple .max file
Just upload it - much faster for you than creating a youtube video and much more information for us to work with...
Edit: Sorry, did not spot the attached file below the video!
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 5 of 10
RobH2
It isn't the same problem. I can't reproduce it. I just wanted to inspect your file and see if I can find anything in it causing the issue.
Rob Holmes
Message 6 of 10
santaclous
You want to help but you don't know how to make a box, select box and plane and make a simple animation like me? Everything is shown in the video.
Here is an animation like in a movie
@santaclous -this post has been edited due to Community Rules & Etiquette violation.
Message 7 of 10
MartinBeh
First thing to notice:
Your two objects have different animation controllers. The plane uses "TCB Position" controllers, whereas the box uses "Position XYZ" with linear tangents - which means they interpolate differently between key frames.
Second:
The plane is at z = 113.714 and the box is at z = 98.156 - which explains why they are at different heights.
Message 8 of 10
RobH2
@santaclous   I want to encourage you to tamp down on your unprofessional comments. We are all here trying  to help each other and none of us gets paid. We do it because we want to assist “positive” and “professional” users.
@RobH2 - the quoted material has been edited by the moderation team
Rob Holmes
Message 9 of 10
santaclous
Second:
First thing Have you watched my movie? Do you understand that plane jumps when I add movement in the X direction.
Second: The box is only there so you can see how the plane jumps.
I change TCB to XYZ
@santaclous - this post has been edited due to Community Rules & Etiquette violation.
Message 10 of 10
RobH2
@MartinBeh   If you agree with me, it's time to let this post go and help other users.
Rob Holmes
