I have a dummy object that is wired to other objects in the scene. I've animated the dummy object's rotation. All good. However I need to be able to turn off the animation so that I can animate other objects in the scene and render them out using a different camera. I tried using animation layers, but as soon as you add another layer, the wired objects no longer rotate. Any suggestions?
