How to rotate cylinder shape without "Wobble"
02:09 PM
So I'm trying to animate a "concrete mixing barrel" rotating. Should be easy enough. However, I just spent the last two hours trouble shooting this - when I rotate it (Local and view) it does this awkward wobble and far from the smooth rotation I want. I've played with the pivot options and reset it, and even tried to place it manually to see if I can get a better outcome. I also tried recreating the "mixing barrel" with a much lower poly version to see if it was the "Complexity" of it that messed something up, but the same happend there. Only with a plane cylinder do I get the result I want.
Tips? See the attached screen capture.
