Exporting animated character from maya to 3dsmax
I have a project i did everything in maya (rigging skining and anination) but i need to render in 3ds max for some reason. I tried many ways to export the character from maya into max but it is not working. Does anyone advive me what to do and how to do it.
Again i animated in maya but i need to send the aninated character to max to render it with the scene.
If you can give me solution as soon as possible
ads_royje
Hi @Anonymous,
What is not working specially ?
Is it meshes, skinning, animation ?
If it is about Animation, when exporting from Maya to Max, Export as FBX.
In the FBX menu, there are File Type Options > Presets
Using the "Autodesk Media & Entertainment" preset should give the same results in Max.
Some animation Rigs, like HIK or custom rig can use Maya (position, orientation) Constraints or other advanced scripting.
In these cases, I would recommend to use the above preset "Autodesk Media & Entertainment" preset.
And modify in Animation > Bake Animation to ON.
Some issues 'may' occur with rotations between Maya and Max. You can experiment with the Animation > Extra Options > Quaternion Interpolation Mode
"Retain Quaternion Interpolation" give the best results in general.
I hope this can help, if not, let me know!
So what to do step by step please.
Should i selcet only the mesh or with the bones or with contoles.
And if i exported fbc should i cash the meshe or bake anything or what.
Thank you allot in advance
ads_royje
Hi again! 🙂
Here is a step-by-step
In Maya,
. File > Export All
. Type > FBX
In the FBX Options
. Choose Autodesk Media & Entertainment preset
. In Include > Animation > Bake Animation : Set it to ON
You can also change the Quaternion Interpolation to : Retain Quaternion Interpolation (This give the best results in most cases, you may try other option if you have issues with Rotations) (Not mandatory)
Export the File
In Max
. File > Import
. Choose the exported file
. in the FBX Import, choose the Autodesk Media & Entertainment preset
. you can go in Animation > Bone Creation > Bone conversion > Set to Leave as Bone (not mandatory)
I've attached a video of this workflow.
I hope this is clearer 🙂
hi again,
thank you allot for your message and your "step by step" video.
thank you for you time.
the process is workin totaly but i have a small problem.
I have a blend shape dor my character. i am talking here about a blink for each eyes. so i have to blendshapes for the blinks. the right are working and the other are not blinking in max. what do you think i should do
