Dope Sheet Highlight properties
erictt
erictt
275223869_1115690715830662_864450529323152164_n.jpgThe rotation property is controlled by an object, how do I find the control object
domo.spaji
Bolded controller in track editors is "Instanced" (copy/paste as istance in track editor UI). It is like "2 way wiring".
You can make it "unique" if you want.
erictt
Finally found it from the Schematic View. When there are thousands of objects in the scene, it's a nightmare. 3dsmax is so bad at this piece of operation
domo.spaji
How did you found it in Schematic View?
