custom attributes and parameter collector advice
hi,
  Looking for some advice please.
   I do alot of technical animations, and have moved from using slide manipulators to custom attributes in dummy objects (most of my stuff involves moving objects rather than manipulating object shapes)
    The custom attributes are great because i can limit the range on them, but if a have number of them Is there a way to show them sperately on the track view?
    Parameter collector is great because i can organise alot of attributes in one place and select keys individualy on track view, but if i limit the values using a float limit, it no-longer show the keys in the track view when i select the parameter is there a script or a way round this?
  Any help of avice would be great.
thanks
VishnuR
I'm not sure of a way around this but maybe some other specialists in this area might respond.
One place you might find scripts if not already tried:
www.scriptspot.com
Do a search there for keywords on your issue.
Hope it helps.
Regards
VR
Vishnu Ramdass
hi,
  Had a look the already, found some very useful scripts but not what i was after. I will keep looking.
