Copy and paste pose/bone whilst posing CAT rig
t_smith5
Message 1 of 10
t_smith5
Hi
Can you only copy and paste bones from one side of a CAT rig to the other when it's in the default position? Is this the only way? I've noticed that whilst posing my rig with the Layer Manager, I'm unable to click on the Copy and Paste buttons to copy the right posed arm to the left.
The mesh is symmetrical, and I've mirrored the weights, but the posed right hand and fingers don't seem to mirror over correctly. 😕
Replies (9)
Message 2 of 10
RobH2
I'm sorry you've gotten no response on this. It's not in my skill set so I can't help but I did want to check in. I'm sure you've done some Googleing. Did you ever solve it? If you did, can you post your solution in case it helps someone else?
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 3 of 10
t_smith5
Hi
Nope. I never did manage to figure it out. I had to just pose the other side manually. 😕 Due to the lack of response, I completely forgot all about this thread.
Message 4 of 10
carrionfernandez
Maybe I am a "littel" late 😅 but here is my way to do that. This is my littel tutorial, any questions please tell me.
P.S: I use Poser Mixer, but now in 2025 doesnt work anymore, I dont understand why.
Message 5 of 10
t_smith5
Thanks for the response and mini tutorial. When I get around to working with a CAT rig again, I'll be sure to give this a try. 😄
Message 6 of 10
divaworks
Oh m'goodness!  I believe I have finally an answer to something!  What has worked for me is this:
1. Select the limb with the animation on it
2. Right Click - Select "Save Pose" and save the pose with a name you'll recognize later
3. Select the limb that the pose is to be mirrored to
4. Right Click - Select "Load Pose".  Select your saved pose and the limb should pop into place!  If you've saved several poses you may have to scroll down the list to find the pose you're looking for.
(I'm using Max 2023)
2 years late but I hope it helps someone.  If it does, pls let me know I got it right.  It will make my day.
Message 7 of 10
RobH2
Thanks for posting that so that it helps others. Sorry I could not help and that it took a long time to figure out but at least now you have a solution. Nice job!
Rob Holmes
Message 8 of 10
t_smith5
Thanks for sharing this. Again, the next time I play around with CAT rigs, I’ll be sure to give this a try. 😄
Message 9 of 10
stephenstacy1
This may not solve your issue, but I found this additional script also helpful - CAT Pose Grabber
It can fill it where the default CAT Clip/Pose tool can't quite do the job.
https://www.scriptspot.com/3ds-max/scripts/cat-pose-grabber
Message 10 of 10
divaworks
Thanks @stephenstacy1.  I'll give this a shot when I have time.  Every little bit helps!
