CAT bones distort after adding ABS layer and toggling animation mode
I've been following a Pluralsight tutorial on CAT rigging, and have reached the point where the rig is nearly complete. Before adding gizmos, animation mode does not show any problems. After adding gizmos, when I enter animation mode the bones skew all weird.
With the controllers there, I can't freeze the transformations. Please tell me what I'm missing.
jon.bell
Have you applied any non-uniform scaling to objects in your scene that you've parented together and/or are trying to rig? Doing this can often mess up your animation when you starting moving the objects in a hierarchy -- objects will start rotating or skewing strangely.
If this is the case (and I'm sorry I have to suggest this), can you do a Reset XForm on all your objects and then re-rig them?
Please let us know if this helps.
Best regards,
Jon A. Bell
Autodesk Technical Support
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
