CAT animation problem
napon
Observer Observer
napon
Observer
Observer
Pls. see attached file for my CAT animation setting.
I have one problem at frame 8973 when it fully uses Absulute layer : grab tank.
From this frame when I start to make a walk cycle if I move M_Rplatform up, the whole body will move up too.
Unlike M Lplatform which works correctly.
Do you have any suggestion?
I using max 2018 on windows 10
ads_royje
Hi @napon,
the effect you are seeing is related to the M_RPlatform Retargeting value.
When Retargeting is not 0.0 is starts to push in/out the limb's parent and keeping the Limbs pose.
Set the Retargeting value to 0.0 it'll behave as you expect.
I hope this can help! 🙂
