Everytime I open my 3dStudio max 9 program I get this error message:
DLL<C:\program files (x86)\3ds Max 9\stdplugs\Dx Plugins\DxDDS.bmi> failed to initialize. Error Code 998 - Invalid access to memory location
What is this and what does it mean? I have reinstalled the program in the hopes of ridding myself of this but nothing has worked. What can I do?
I an operating a Windows 7 upgraded from a Windows XP. It runs on a 32 bit format.
3ds max 9 wasn't made to run on windows 7 it couldn't even run on on vista without a service pack
you can try running in compatibility mode
if this doesn't work you need to upgrade to a new version of Max or downgrade your OS back to XP
DarrenP
this is a windows feature not guranteed to work with 3ds max 9
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
DarrenP
it looks like SP2 may fix your problem but you will need to determine that on Windows 7
DarrenP
I think you all have been right. I amset up as my Administrator but I keep Getting the message:
"You have insufficient rights. Restart you computer, login with local administrator rights and try again to complete the intallation or uninstallation. If this problem persists, contact your system administrator or authorized Autodesk prosuct dealer.
Error [4.297.1007]"
I have tried everything to get the two service packs to load but both of them show up with this problem. How can I get around it?
you don't
your trying to run old software on a newer OS downgrade your OS or upgrade 3ds max
DarrenP
try downgrading your OS back to XP
DarrenP
Hello @Anonymous,
System specs? OS details? Need more information than you've given us.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
did you read the entire thread?
DarrenP
