I have a problem with autogrid in 3ds max 2015.
after chamfering all edges of a side of a box ,autogrid does not work well on that side of box.
any help?
Solved by aon.914858227. Go to Solution.
thank you Steve, but I think you got me wrong. Sorry, my english is not good enough to describe the situation, but I'll try it.
This problem is just in 3ds max 2015.
Please make a big box. Then convert it to editable poly and chamfer around edges of one side of box, with at least 2 edge segment and chamfer amount, for example (0.1) . now try to make a big plane on that side of box by autogrid. The problem is here. the point you start the plane is on the poly but the rest of plane is not exactly on the poly .( the plane is not aligned with the poly of the box.
I hope I could describe the problem.
Thx again
Steve understood you perfectly well.
Like he said it`s because of the new Smoothing options in the chamfer feature.
There are two options 'Entire object' or 'Chamfers only'.
Choose the second and you will get the expected behavior.
