Hi everyone, i had an issue with the pivot point in 3ds max, I'm making a car and i want to open the doors, every door is a group, so to make the opening correctly, I've changed the pivot point.
The rotation works fine but when I close the file (saving it off course) and i open the file again, the pivot of the doors are aligned again to the center, and i need them to stay where i put them. How can i solve this problem? Thanks in advance.
Solved by Steve_Curley. Go to Solution.
Thanks for the tip Steve, it worked perfectly, i have never worked with dummys before, i learnt something new today thank you.
