Pipe run defaults
Two questions regarding pipe runs...
1) I have default pressure networks created in our template. The parts lists are set correctly and the layers are set correctly but if I create a pipe run by path, C3D defaults to the parts list defined in the command settings, not the parts list defined in the network properties. However, if I create from object, it does use the correct parts list as defined in the networks properties.
How do I get the pipe run by path command to use the correct parts list?
2) Is there any way to control the pipe run alignment layer? It's currently using the current layer and although my pipe runs alignments are set to a no plot style, I'd like them to be on the specific utility layer. This request isn't as crucial as question 1.
TIA
Civil 3D 2022.2.5
