Structure Label Style for Pressure Pipe Connection
bdraper
bdraper
In Civil 3d 2025 I am able to connect a pressure pipe to a gravity structure, however when you add a structure label it does not recognize the pressure pipe connection. Does anyone have a work around?
Brian
sirjoelsph
Hey Brian,
The structure label style controls this.  Since they added the capability to attach pressure pipes to gravity structures, they also added a category to structure labels on how to label those pressure pipes.  You will need a component that is set to label pressure pipes.  When you add a "Text for Each" component, the "Structure all pipes" and "Structure all pressure pipes" options will label your pressure pipes.  If your current label style only includes in and out flow pipes, those will only label gravity pipes.
-JOEL
bdraper
Hi sirjoelsph
I have opened both imperial and metric civil 3d templates, however I do not see the "Structure all pipes" and "Structure all pressure pipes" options when I create a new Structure label component.
Am I missing something?
sirjoelsph
It has to be a "Text for Each" component.  Regular text components won't give you the options.
-JOEL
bdraper
Thanks sirjoelsph
Thats what was needed
bdraper
Thanks Joel that was what I needed.
