Screen flashes when using civil3D 2025
kristaps_krastins_2
Message 1 of 9
kristaps_krastins_2
I have a civil3d 2025 student account.
When using the program screen flashes if i am in the window of civil. When i go out of civil window the problem stops. It flashes and stutters for a milisecond on any selection of button, option or line.
If i have a split window with 2 programs, ehen in civil the whole screen flashes and stutters, when i use chrome for example the flashing stops.
Hardware - RTX 4070, Ryzen 7900x, 32gb DDR5 RAM
All of drivers are up to date and GPU drivers have been reinstalled.
what could be the problem and the solution?
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
@kristaps_krastins_2 Start here (long list of items to do) if simply turning off GFXDX12 variable then restarting your C3D2025 does not help
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Drawing-window-fli...
Message 3 of 9
kristaps_krastins_2
I have done all of these solution resolvements.
I dont see any improvements when i am using only autocad.
I just tried to screen record the problem, but it does not show on the recording. Once when screen recording it just stopped but re-started when i ended screen recording.
Just reinstalled newest drivers for everything. Only autocad is making this problem so i cant see the hardware being faulty.
Message 4 of 9
brian.strandberg
Make sure that CAD is recognizing your graphics card. I have seen issues where it recognizes the onboard video instead of the GPU. You can see which one Civil 3d is recognizing with the 3dconfig.
If you are an admin, go into the command prompt and run SFC /scannow
Update your systems graphics drivers.  I see several issues like this that are fixed with updates.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 9
pendean
Community Legend
Community Legend
@kristaps_krastins_2 wrote:
...I just tried to screen record the problem, but it does not show on the recording...
Use your phone then.
Message 6 of 9
brian.strandberg
I also wouldn't rule out a cable issue.  I have one funky monitor that drops out for like 10 seconds a day always when I'm busiest.
Message 7 of 9
kristaps_krastins_2
Have changed to a differend display pord cable and checked if the right video card is recognised.
I will try to re-seat the GPU when i have the time, and hope that fixes issues, but all of this is weird, cant seem to get any solution to work.
Message 8 of 9
kristaps_krastins_2
Hope this works, bad video, but it should seem to show the problem.
when i am not in Civil, every problem stops, when i am i am in it, it flashes. seems like a little flashing now but when i start to do any jobs, the eyes are getting worn out pretty quickly
Message 9 of 9
kristaps_krastins_2
The real problem was with monitor settings. I did not know the AMD FreeSync was turned on automatically on my monitor. When started to watch other programs with more caution, they had the same flashing problem but a lot less.
Hope it maybe helps others some day to not try and think the pc is broken!
