SSS issues for ice cream, C4D
cpz
Message 1 of 8
cpz
ice-cream.jpgHi, please see attached; my shadow areas are grey in the strawberry and banana part of the ice cream-I have used, not shown here, the TM for color in SSS, but the SSS part is not reflective of the color, same results as here , any thoughts,? in other words, would love to get a nice pinkish glow in the crevices for the strawberry part, but I am stumped, I use C4D, thank you
Replies (7)
Message 2 of 8
lee_griggs
Are you using sss_color?
I would increase the sss_scale for all of your shaders here.
Can you share your SSS settings?
These tutorials may also help:
https://www.youtube.com/watch?v=2fWu3hAwLPg
https://www.youtube.com/watch?v=s8Bq5Ou_Plc
https://www.youtube.com/watch?v=rrvCfTwqeVo
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 8
cpz
Screen Shot 2020-05-26 at 9.51.21 AM.png thank you Lee, any revelations would be awesome, Craig, BTW, stay safe
Message 4 of 8
cpz
Hi Lee, did you get my screenshot of my settings? are you suggesting that I increase the RGB settings of the SSS only ? thank you, Craig
Message 5 of 8
lee_griggs
I would increase the sss_weight and play around with the sss_scale.
You should use randomwalk_v2 also.
If that doesn't help then upload a simplified scene somewhere and I will have a play.
Lee Griggs
AUTODESK
Message 6 of 8
cpz
Hi Lee, unfortunately my file sizes are way too big!-I used 4K maps created in Z brush, even after using a sphere instead of my ice cream model, just the TM is about 56 mgs. If there is an alternative way to share my file with you, I know that I would benefit greatly.Please let me know, I value your opinion, thank you, Craig
Message 7 of 8
lee_griggs
That should be fine. Just upload it somewhere so that I can look at it.
Did you try the changes that I recommended? Can you post the renders?
Lee Griggs
AUTODESK
Message 8 of 8
daniel
And be sure to check the Export scale setting in the Arnold Render System Settings tab. 1cm should be the right value for realistic dimensions
