How to create Throughput per hour from Process Flow Model
sudharsan_r
sudharsan_r
[ FlexSim 20.1.0 ]
Hi All,
I am beginner in Flexim and i had created the Process flow model to check the throughput of bags in the screening machine(EDX1).
I have created a Entry zone for the bags to enter into the screening zone and i have created a resource for the screening machine(EDX1). I need to create a Throughput per hour chart for the screening machine in dashboard.
Also, i need to create the queueing chart for number of bags in queue at the entry zone(EDX1).
Refer the Process flow below,
Can anyone help me on this.
Many Thanks,
Sudharsan R
braydn_t
@Sudharsan R You can add a throughput per hour chart to a dashboard, and use the eyedropper to select whatever you want the chart to listen to. If you upload your model, I can help you a little bit easier. If it is proprietary, we can make the question private.
sudharsan_r
@Braydn T: Thanks for your reply. I have fixed the issue.
Sudharsan R
