Starting in FlexSim 7.5, the AGV Module was included in FlexSim's installer.
When you run the installer, check the box to install the AGV Module:
If you didn't check that box, uninstall FlexSim 7.5 and reinstall, checking the box.
The AGV module is no longer distributed as a separate installer. It is included with the standard FlexSim installer.
The earliest version of the AGV module was a separate installer and worked with FlexSim 7.1. There was also another version that worked with FlexSim 7.3 that was a separate installer. Neither of those separate AGV installers are available for download anymore.
Phil BoBo
Sr. Manager, Software Development
