When opening a 3rd party drawing the navvbar/cube whatever it's called is there in every viewport I activate in paperspace. 10+ yeras down the road after this was asked first and still no solution.
Freaking insane. I want them gone, like topicstarter:
PERMANENTLY AND FOREVER
NAVVCUBEDISPLAY => 0
NAVBAR => OFF
Put this in your ACADDOC.lsp and you'll never see the Nav stuff again.
(setq nonav_login (getvar "loginname"))
(if (= nonav_login "YOURLOGINNAME");<--Change "YOURLOGINNAME" to your actual login name
(progn
(setvar "NAVVCUBEDISPLAY" 0)
(command "NAVBAR" "off")
Agree have that in my "autoload.lsp" a lisp that is loaded via Appload "Start up suite", find it easier to have a custom one rather than play with acaddoc.lsp. Think upgrades, just do Appload and save to Start up suite again all done.
The autoload.lsp has lots of stuff in it.
I use an initialization lsp that sets support paths and trusted dirs. There's an acaddoc.lsp in the support path with only 2 lines in it for loading a startup lsp. Drag and drop the initialization lsp onto new users PC's and they're all set. Works for upgrades as well.
