I need help with an AutoCAD LISP that correctly identifies the linetype of a selected object, but fails to include objects with their linetype set to "ByLayer" that match the linetype at their layer level. Can you modify the lisp so it selects objects appearing with a certain linetype, whether directly assigned or via their layer, ensuring all relevant objects are included in the selection set?
(defun c:FLT2 (/ ent obj layerName linetype ss ltypeFilter activeDoc layers)
(vl-load-com)
;; Prompt user to select an object and determine its linetype
(setq ent (car (entsel "\nSelect an object to determine its linetype: ")))
(if (not ent)
(progn
(princ "No object selected. Exiting.")
(exit)
;; Get the object and check linetype
(setq obj (vlax-ename->vla-object ent))
(setq linetype (vla-get-Linetype obj))
;; If linetype is by layer, retrieve from layer
(setq activeDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq layers (vla-get-Layers activeDoc))
(if (= linetype "ByLayer")
(progn
(setq layerName (vla-get-Layer obj))
(setq obj (vla-item layers layerName))
;; Inform the user of the linetype
(princ (strcat "\nThe linetype of the selected object is: " linetype))
;; Construct the selection filter
(setq ltypeFilter (list (cons 6 linetype)))
;; Prompt user to make a selection set filtered by linetype
(setq ss (ssget ltypeFilter))
(if (not ss)
(princ "\nNo objects found with the same linetype.")
(progn
(sssetfirst nil ss)
(princ (strcat "\nFiltered selection set by linetype: " linetype))
(princ)
Solved by komondormrex. Go to Solution.
check this
(defun c:all_linetype (/ linetype_ename linetype layer_linetype linetype linetype_sset linetype_list)
(setq linetype_ename (car (entsel "\nSelect an object to determine its linetype: ")))
(if linetype_ename
(progn
(if (null (setq linetype (cdr (assoc 6 (entget linetype_ename)))))
(setq linetype (vla-get-linetype (vla-item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(cdr (assoc 8 (entget linetype_ename)))
(princ (strcat "\n\n\"" linetype "\" is selected linetype"))
(vlax-map-collection (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
'(lambda (layer) (if (and (= (strcase linetype) (strcase (vla-get-linetype layer)))
(not (member (vla-get-name layer) layer_linetype))
(setq layer_linetype (append layer_linetype (list (vla-get-name layer))))
(setq linetype_sset (ssget "_x" (append (list '(-4 . "<or")
(cons 6 linetype)
(if layer_linetype
(list
(cons 8 (apply 'strcat (cdr (apply 'append (mapcar '(lambda (layer) (list "," layer)) layer_linetype)))))
'((-4 . "or>"))
linetype_list (vl-remove-if-not '(lambda (ename) (or (null (assoc 6 (entget ename)))
(= (strcase linetype) (strcase (cdr (assoc 6 (entget ename)))))
(vl-remove-if 'listp (mapcar 'cadr (ssnamex linetype_sset))))
linetype_sset (ssadd)
(foreach ename linetype_list (ssadd ename linetype_sset))
(sssetfirst nil linetype_sset)
(princ)
Using the same approach, is it possible to modify this to filter selection according to lineweight instead of linetype?
Thanks again!
Edit:
I got this far, but I still need it to determine LWDEFAULT to get the default lineweight from the active drawing,
then modify selection criteria: When "-3" (default) or "-2" (byblock) values are selected, treat these as equivalent to LWDEFAULT.
(defun c:FLW (/ lineweight_ename lineweight layer_lineweight lineweight_sset lineweight_list)
(setq lineweight_ename (car (entsel "\nSelect an object to determine its lineweight: ")))
(if lineweight_ename
(progn
(setq lineweight (cdr (assoc 370 (entget lineweight_ename))))
(if (= lineweight nil)
(setq lineweight (vla-get-Lineweight
(vla-item
(vla-get-layers
(cdr (assoc 8 (entget lineweight_ename)))))))
(princ (strcat "\n\n\"" (itoa lineweight) "\" is the selected lineweight"))
(setq layer_lineweight nil)
(function (lambda (layer)
(if (= lineweight (vla-get-Lineweight layer))
(append layer_lineweight (list (vla-get-name layer))))))))
(setq lineweight_sset
(ssget
(append
(list '(-4 . "<or") '(-4 . "<and") '(0 . "*") (cons 370 lineweight) '(-4 . "and>"))
(if layer_lineweight
(list '(-4 . "<and") '(0 . "*")
(cdr (apply 'append
(mapcar (function (lambda (layer)
(list "," layer)))
layer_lineweight)))))
'(-4 . "and>"))
nil)
'((-4 . "or>")))))
(setq lineweight_list
(vl-remove-if-not
(function (lambda (ename)
(or (null (assoc 370 (entget ename)))
(= lineweight (cdr (assoc 370 (entget ename)))))))
(vl-remove-if 'listp (mapcar 'cadr (ssnamex lineweight_sset)))))
(foreach ename lineweight_list
(ssadd ename lineweight_sset))
(sssetfirst nil lineweight_sset)
(princ)
here is mine
(defun c:all_lineweight (/ lw_assoc lineweight_ename lineweight layer_lineweight lineweight lineweight_sset lineweight_list)
(setq lw_assoc '((-1 . "ByLayer") (-2 . "ByBlock") (-3 . "Default"))
(progn
(if (null (setq lineweight (cdr (assoc 370 (entget lineweight_ename)))))
(setq lineweight (vla-get-lineweight (vla-item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(princ (strcat "\n\n\"" (if (assoc lineweight lw_assoc) (cdr (assoc lineweight lw_assoc)) (vl-princ-to-string (* lineweight 1e-2))) "\" is selected lineweight"))
'(lambda (layer) (if (and (= lineweight (vla-get-lineweight layer))
(not (member (vla-get-name layer) layer_lineweight))
(setq layer_lineweight (append layer_lineweight (list (vla-get-name layer))))
(setq lineweight_sset (ssget "_x" (append (list '(-4 . "<or")
(list
(cons 8 (apply 'strcat (cdr (apply 'append (mapcar '(lambda (layer) (list "," layer)) layer_lineweight)))))
'((-4 . "or>"))
lineweight_list (vl-remove-if-not '(lambda (ename) (or (null (assoc 370 (entget ename)))
lineweight_sset (ssadd)
(foreach ename lineweight_list (ssadd ename lineweight_sset))
(princ)
Can you combine the 3 values: "-3" (default) and "-2" (byblock) and "#" (lwdefault) and treat them as one?
So the lisp initially checks for (getvar "lwdefault") value, and if user picks an object of any of the above 3 values, it filters the selection to include all 3?
So in simple terms i need to select everything that visually has the same lineweight, regardless of whether it's set as "default" or "byblock".
like that?
(defun c:all_lineweight (/ lineweight_ename lineweight layer_lineweight lineweight lineweight_sset lineweight_list lineweight_value_list)
(progn
(if (member lineweight '(-2 -3)) (setq lineweight_value_list (list -2 -3 (getvar 'lwdefault)))
(if (= lineweight (getvar 'lwdefault))
(setq lineweight_value_list (list lineweight))
(princ (strcat "\n\n\"" (vl-princ-to-string (* (last lineweight_value_list) 1e-2)) "\" is selected lineweight"))
'(lambda (layer) (if (and (member (vla-get-lineweight layer) lineweight_value_list)
'(-4 . "<or")
(mapcar '(lambda (lweight) (cons 370 lweight)) lineweight_value_list)
(list '(-4 . "or>"))
(list
'((-4 . "or>"))
(member (cdr (assoc 370 (entget ename))) lineweight_value_list)
(princ)
