PLEASE HELP!
I have school, and this is a big project that I have beenhaving a really tough time with. I seem to be getting problem after problem with maya, all of which i can usually fix. Not today. I searched and searched for an answer yet no one has had it happened it seems.
So I am creating a cluster of leaves in maya. These leaves are simply textures on top of a plane. I go to render, and everything looks pretty and nice. So I save, than open photoshop. To find it blacked out. All except the alpha. I am so confused and have no idea what to do please help.
Solved by dnrartist. Go to Solution.
This looks like a color management setting that might be wrong for your workflow perhaps, I would start looking into that...if is just a single render maybe you are not saving a color corrected image from the render view...again is hard to say from over here.....maybe these videos might help you..........https://www.youtube.com/watch?v=IC051nGKTmI
https://www.youtube.com/watch?v=XIP3yF_KteI
So i looked over the videos and tried applying all changes I could to see if it would work. It did not, I am not sure how color management will affect the saved file though.
If you can upload your scene someone here can take a look or , just describe more in detail what the scene is being used for and more screen grabs if you can.
Actually I found out what was the issue. Well I think two things were the issue. First I think my file got a little corrupted somehow which caused that error. I noticed when I exported the leaves into another scene I could render it, and I almost headbanged, but than I noticed some visual information in the regular layer. I increased the intensity of the lighting in photoshop and now I see everything with full detail.
I think my original scene did have a weird setting turned on, it somehow made my saved image files blacker than black. I should have just checked the pictures brightness from the first place. Thanks for the help though.
